Rocker Arm and Cam belt broken
ricky1329
Post Fri Apr 15, 2016 8:48 am
Found one rocker arm broken; cam belt broken after open the valve cover.
Found 1,3,5,6 exhaust valve damage after removal the cylinder head.
Piston surface seem still OK, just little scratch mark from value.
Did I really need a new rebuilt engine or just rebuilt cylinder head is good enough?
I want post photos but don't know how to make it
Looking forward comments.
Post Fri Apr 15, 2016 9:12 am
Sounds like new/refurbished cylinder head is required - or rebuild your old one. What engine is it?
ricky1329
Post Fri Apr 15, 2016 9:16 am
Speedtouch wrote:Sounds like new/refurbished cylinder head is required - or rebuild your old one. What engine is it?
M20b25
Post Fri Apr 15, 2016 9:45 pm
Yes, in that case, as above. Hopefully, your old head should be repairable, but in the meantime it would probably be easier/quicker/cheaper to source another head from here/E-bay/breakers yard, etc.
ricky1329
Post Sat Apr 16, 2016 4:06 am
Thanks comments and attached some pics FYI.
reggid
Post Sat Apr 16, 2016 4:45 am
hopefully any valves that touched the pistons didnt pinch a ring
E30 325is with M20B31
ricky1329
Post Sat Apr 16, 2016 6:30 am
I try to rotate the crankshaft and found the pistons up and down smoothly.
Yeti
Post Sun Apr 17, 2016 9:08 pm
as long as the bottom end rotates mate you will be fine, take the head to a specailist and they will check the head i.e cracks , pressure test it and change the valves that are needed dude :D
