I'm changing my rad. At the moment I have the standard e36 type with the side mounted expansion tank. I'm putting a supercharger on my m50b25 and there won't be room for the expansion type. I'm considering one of these: https://www.ebay.co.uk/ulk/itm/172025043854
With this would I just run the bottom hose that would have gone to the old expansion to a new remote expansion?
Or considering one of these: https://www.ebay.co.uk/ulk/itm/111867288565
If I go for the s14 type what would I do with the hose that used to go to the bottom of the expansion tank?
Aluminium radiators?
That first one will be a twin 18mm tube, they are very good for the money, you would struggle to buy the cost of labour involved for that much in the UK. 100% Chinese built, the same as the likes of mishimoto and similar makes.
Yep, just move the expansion tank, the top small bleed off also goes to the expansion tank
ropeman
- Avid Zone reader
Yeah, thought that was a pretty keen price. Any ideas how I would plumb in the s14 type?DanThe wrote:That first one will be a twin 18mm tube, they are very good for the money, you would struggle to buy the cost of labour involved for that much in the UK. 100% Chinese built, the same as the likes of mishimoto and similar makes.
I expect you will need to cut lumps out of your car to get that to fit
ropeman
- Avid Zone reader
Ah, ok. Think I'll go with plan A then. Thanks.DanThe wrote:I expect you will need to cut lumps out of your car to get that to fit
