So I'm currently trying to fit a new Mocal Oil cooler to the 325. But I've hit a massive problem of the new sandwich plate having a male screw thread to attach to the block, but then nothing to attach the oil filter too, or needing a filter with another male thread. I know these aren't very common if at all.
Just wondering if anyone else has had any experience fitting aftermarket oil coolers the the M20 engines?
Cheers people!
Mocal Oil cooler
gromgsxr
are you using the 325i oil cooler take off or the mocal plate directly to the block?
JE1991
The Mocal kit came with a new sandwich plate, which is the bit I'm struggling with. If there is a way to use to 325I take off that would be perfect!
maggspower
- Turbo Farmer Tractor Driver
Use the standard e30 take off, and filter. Then custom lines to your new cooler.
Contact: theengineshedonline@gmail.com
gromgsxr
or use the double ended male threaded bit thats in a m20b20 block and use the mocal plate.
The standard take off incorporates a thermostat, which in normally use rarely directs oil through the cooler. Overcooled oil is as bad as overheated oil.
JE1991
Awesome, does anyone know if you can get 1/2 bsp adaptors for the m20b25 take off so they fit the new pipes? Or is it a full custom job.
Cheers for the help so far! Appreciate it!
