Eta with m20b25 piston?
Benzon
Post Thu Mar 24, 2016 7:41 am
Hey, I got a m20b25 block with 2.7 81mm crank, with eta pistons. Also I have the 885 head unit.
Will I be able to use m20b25 pistons, instead of eta pistons? If I use the rods from eta?. Will it work ?
reggid
Post Thu Mar 24, 2016 8:51 am
m20b27 crank, m20b27 rod, m20b25 piston, ~2mm off the top of block
http://www.e30zone.net/e30zonewiki/inde ... ding_a_2.7
E30 325is with M20B31
jimbom30cab
Tech 1 freak
Post Thu Mar 24, 2016 11:09 am
Might also need a vernier pulley for timing if 2mm off block
