Fuse 20 - no power
jimbom30cab
Tech 1 freak
Post Fri Mar 18, 2016 12:50 pm
Investigating why the power mirrors and heater fan are not working.
1987 325i
There is no battery voltage when in "run" at fuse 20. Battery is connected and at 12.5v.
Relay K7 is fitted and i've swapped it for another (though can't vouch for it's condition)
Relay pin socket is live no. 86.
Could i have a couple of duff relays ?
JIm
Post Sat Mar 19, 2016 1:01 am
one of the two smaller connections on the starter motor provide the power to the fuesbox , it's either the 10mm nut or the 8mm one . make sure you disconnect the battery before probing about :wink:
have you fallen out with mr moooore ?
the silence is deafening :? .
jimbom30cab
Tech 1 freak
Post Sat Mar 19, 2016 9:40 am
Thanks mate, that's what Rob (HKF) also said as i've not put the engine back in yet
Not heard from Mr M for a while , maybe he's on holiday ?
Jim
