skimmed head q
scottybeemer
Post Sun Mar 13, 2016 9:28 pm
im doing a head gasket on a m10,if i get the head skimmed should i use a thicker gasket?
"you aint gonna take me alive, copper"
Post Sun Mar 13, 2016 9:36 pm
Few blobs of plasticine on top of a piston, reassemble with a used, compressed gasket and head bolts tight but not torqued down. Turn over by hand, take it apart again, and check the plasticine thickness.
scottybeemer
Post Sun Mar 13, 2016 10:06 pm
Brianmoooore wrote:Few blobs of plasticine on top of a piston, reassemble with a used, compressed gasket and head bolts tight but not torqued down. Turn over by hand, take it apart again, and check the plasticine thickness.
will play doh do lo, cheers
Post Sun Mar 13, 2016 10:16 pm
As long as it squashes and stays squashed!
Yeti
Post Mon Mar 14, 2016 1:43 am
how much did you get skimmed off? 20 thou is only 0.5mm so i shouldnt worrie if so
Post Mon Mar 14, 2016 9:52 am
You can never be sure that you're the first one to skim it, though, plus it's good experience to do the job 'properly'.
