Hello,
Should I use touring rear disc brake? Or stay with sedan rear disc?
I'm in the process of buying the calipers and discs so I think the price more or less will be same.
Does calipers ate 33 is for sedan with solid discs and ate 35/10 for touring with vented discs?
I assume the rear arms are same.
So the different is only at calipers and discs? Or what else should I aware?
Thank you
Markus
rear disc conversion sedan or touring?
markus_74
Touring and saloon both use the same solid rear disc. The only difference in the rear brakes is that the touring uses a slightly larger piston in the caliper.
The difference is small, and as long as you use a matching pair, the choice doesn't really matter.
markus_74
I see a rear vented disc what is it belong? Cabrio?
No E30s with vented rear discs. Nearest thing you will find with these is the Z3M, but those are 5 bolt discs, of course.
markus_74
Thank you Brian. I sorted step by step all parts because I buy the part one by one.
My last question, I see that my drum brake use metal pipe to the master cylinder to push the pad, so if I will use discs brake I should connect it with additional hose(34321108134)?
Definitely need the extra flexible hose. Part # is 34 32 1 159 881. Don't recognise the part number you have.
Lurch320i
When I was researching big brakes for the rear I can across an e30 with rear vented discs
Some 325ix touring had 258x19mm vented rear disc
Part number 34 21 1 165 261 i
Source:http://bmwfans.info/parts-catalog/E30-T ... ar_sensor/
