How often should the valve clearances be checked
jslot
How often (time or mileage) do people reckon the valve clearances should be checked?
When the SI display tells you to, which will be about every 15,000 miles.
aimlessrock
Brian, what about seasonal cars..i doubt i will do 15,000 miles in my cabby in the next 15 years.Brianmoooore wrote:When the SI display tells you to, which will be about every 15,000 miles.
check every 12 months?
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
The inspection light will still indicate when a service is due. We're talking about every other oil service, not the clock symbol, which is simply a 365 day timer.
Cold starts will probably be a bit more of the total driving for your car than one that is in daily use, so the light will come on slightly earlier, but not a great amount
jslot
Thanks Brian
