Headlight Adjusters
Mitchen
Post Wed Feb 24, 2016 4:12 pm
I've discovered the rods at the end of this system are just laying around in the engine bay behind the plastic covers.
I've looked around the headlights for somewhere where they attach, screw, anything.. but can't see anything.
Any ideas or pics chaps?
1990 320i Coupe SE
viewtopic.php?t=253048
BenHar
Post Wed Feb 24, 2016 5:19 pm
There's a picture here that shows where they go: http://www.e30zone.net/e30zonewiki/inde ... Conversion
Ben
Post Wed Feb 24, 2016 5:53 pm
Take a pic of the rear of the lights and post back.
And i'll tell you whats missing
Post Wed Feb 24, 2016 6:34 pm
Unless your outer headlamps are flapping around in the breeze, the hydraulic adjusters have probably been replaced by manual ones. (Unless the headlamp rim has been glued to the grill with black silicon rubber, like on one E30 that came my way.)
Mitchen
Post Wed Feb 24, 2016 9:03 pm
The car's previously had a respray, where I'm assuming the front grills and headlights etc were removed. Looks like whoever put them back didnt know where the rods go and just left them unattached laying around by the lights.
I have no idea how it's supposed to look, or even how the hydraulic system works... But I can confirm my headlights aren't flapping around in the breeze.
1990 320i Coupe SE
Cloggy Saint
Post Wed Feb 24, 2016 9:23 pm
Mitchen wrote: I have no idea how it's supposed to look, or even how the hydraulic system works...
It almost certainly doesn't work :(
Mitchen
Post Wed Feb 24, 2016 9:25 pm
... or supposed to work :P
1990 320i Coupe SE
BenHar
Post Wed Feb 24, 2016 10:00 pm
BenHar wrote:There's a picture here that shows where they go: http://www.e30zone.net/e30zonewiki/inde ... Conversion
Ben
Mitchen
Post Wed Feb 24, 2016 11:19 pm
Thanks Ben..
Although I can't for the life of me see where on there the rod is going in?
Is it the one next to the main beam?
1990 320i Coupe SE
Post Wed Feb 24, 2016 11:25 pm
They fit on the outer side, next to the inner wing. As I said earlier, if the lights aren't flapping about, there must be a manual adjuster fitted in their place.
Post Thu Feb 25, 2016 12:55 am
Take a pic and post it here.
You're either missing the black bush that inserts into the light housing that the rod fsnaps into, or the rod is broken inside the hydraulic adjuster.
BenHar
Post Thu Feb 25, 2016 9:37 am
Mitchen wrote:Thanks Ben..
Look at the right of the headlights in the picture. You can see the plastic pipe from the headlamp adjustment system going into a black cylinder. The bottom headlight mounting pin sticks out of the front of that cylinder.
Ben
