Lads,
Question - I am currently running Eibach springs, Bilstein shocks, and Eibach Sway bars on E30 M3 suspension with the M52.
I'm finding the Eibach's SLIGHTLY too low - but absolutely love the handling.
Any suggestions on something that'll give me the same level of handling but a little less likely to ground out on London speed bumps? I've tried H&R springs in the past and would be open to trying again, but thoughts on anything different? Any where is the best place to buy H&R online?
Cheers!
Gus
Spring Suggestions - lower than MTech, higher than Eibach
JungleGus
"lower than MTech, higher than Eibach". There's only 10mm, theoretically, between the two.
Fine tune with different thickness's of rubber spring pads.
JungleGus
Wisdom...
Thank you!
Thank you!
