Ignition leads
Jookeone
Post Mon Feb 15, 2016 4:40 am
Can anyone advise on which ignition leads I should fit as a standard replacement. I'm not sure of the OEM manufacturer but don't feel like paying over £100 on a brand I've never heard of from GSF...
Any advise appreciated, thanks.
TPS
Post Mon Feb 15, 2016 6:39 am
What Engine is it?
Jookeone
Post Mon Feb 15, 2016 6:43 am
Sorry I was missing key info... M20B25 in a pre-facelift car.
Post Mon Feb 15, 2016 9:53 am
Short answer is I wouldn't buy new. Plenty of second hand original ones around in mint condition.
Ignition leads aren't a service item on E30s like they were with those on inferior makes from the same era.
Jookeone
Post Tue Feb 16, 2016 8:49 am
So you'd suggest second hand from eBay or the like? I was really hoping to get new, but considering what you have said I'll have a look about for used.
Post Tue Feb 16, 2016 9:53 am
Jookeone wrote:So you'd suggest second hand from eBay or the like? I was really hoping to get new, but considering what you have said I'll have a look about for used.
Try one of the traders on here. Why are you changing them in the first place?
Jookeone
Post Thu Feb 18, 2016 11:54 am
Main reason was due to them not having been changed, but since you mentioned they are not a service item I may leave them.
My concern was added due to a bit of a lumpy idle from cold. I've checked the blue temp sensor resistance and all seems good...
reggid
Post Thu Feb 18, 2016 9:08 pm
the wires do not last forever but OEM last a good amount of time and many aftermarket ones are scrap . if there are no issues with the running or cracks in the insulation etc leave it be.
E30 325is with M20B31
Post Thu Feb 18, 2016 9:46 pm
Jookeone wrote: My concern was added due to a bit of a lumpy idle from cold. I've checked the blue temp sensor resistance and all seems good...
The usual combination of worn injectors and minor air leaks probably.
Jookeone
Post Thu Feb 18, 2016 10:38 pm
Thanks guys,
I'll have a check for cracks etc. and call it a day with the ignition leads then.
I've had a good look around for air leaks previously, but injectors have been on my list of things to do for a while. When the car gets a week or so of down time I'll send them off :D
