E30 320 auto preface to Manual m20b25 parts needed?
ThreeDLee
Post Wed Feb 10, 2016 5:17 pm
Hi i have a 320 auto preface lift and i just wanted help with a list of parts I'm going to need?
Thanks, Lee.
ThreeDLee
Post Sat Feb 13, 2016 10:14 am
Anyone?
Post Sat Feb 13, 2016 1:41 pm
Engine and gearbox, complete with AFM, ECU, gear shift linkage, propshaft and gearbox cross member.
Engine wiring loom, if the ECU has a different number of pins.
Reverse light loom/gearshift grommet.
Clutch reservoir and mount, clutch cylinders and plumbing, clutch pedal or complete pedal box.
Exhaust manifold and system will fit, but will be slightly restrictive.
Diff. will fit, but the engine will be revving higher than necessary.
Radiator and header tank can be retained if you fit your existing water pump (or an identical new one) to the 2.5 engine.
A few minor bits that I've forgotten.
