Any help would be appreciated!
Thanks for the reply, the red wire hanging down is the same wire going in to the junction box, sorry I wasn't very clear! Yes I agree it doesn't look very original!willnz wrote:1st pic, the plugs will only fit into one particular socket in the accessories socket, each socket is unique in shape. Not sure what the red wire going to the middle right is for though?? Does not look like an OEM wire? So cant comment as to where it should go. You will have to trace it and report where it goes to. (possibly to the red wires hanging down in pic 2?
2nd pic- Those 2 plugs are for aircon and auto box so not used in your case. Red wires hanging down again do not look to be part of the OEM wiring loom so who knows? Trace them back..
Facelift B20 and B25 engine looms are identical, but it's still correct that you removed the old loom, even if you reused it with the new engine.brian_s wrote: Yeah I realised after stripping it all out that I could have just used the original loom but just through in the loom attached to the b25 engine seeing as I'd gone that far haha
