E30 325i 1989 has exhaust got a Cat?
M3KUK
Post Mon Jan 25, 2016 6:33 pm
Hi, the exhaust mid section is blowing on my 1989 325i, I'm looking for a replacement do they have a Cat fitted and if so can I remove it? Thanks Mike.
Post Mon Jan 25, 2016 6:47 pm
If it has one, you can replace it with a standard front box and down pipes. Whether it has one or not depends on whether whoever first bought the car specified one.
If it has a cat., there will be a lambda sensor and wiring protruding from near it., and the lambda sensor socket, clipped to the underside of the front battery tray, will have a lead plugged into it, instead of being capped off.
bosers
Post Mon Jan 25, 2016 8:52 pm
Anything registered before 1st August 1992 is not required to have a Cat. I believe.
M3KUK
Post Mon Jan 25, 2016 10:46 pm
Just had another look and it's not got one, thanks!
