I'm looking to up performance a bit in my m50b25 in the lower revs, and from my google searching I see fitting a m20 engine flywheel is a good swap when done but you need to use the correct clutch and release bearing for the flywheel, now can I use any m20 flywheel and starter or is it a specific one ? And the same for the clutch. Also I've read that you need to skim a bit from the flywheel to clear some bolts has anyone got a pic of where you need to take the material away from ?
Thanks in advance
M50b25 flywheel swap
bosers
There's loads on this in the M50/52 swap section, have a butcher's in there. The starter needs to match the fly which can come from any 6 cylinder M20 I think. It does need machining down and slight mod to release fork is needed. Release bearing to match fly is fine.
