Help viscous fan nut
Bally
Post Tue Jan 19, 2016 10:35 am
Hi how do you stop the pulley turning while undoing the viscous fan nut ? On a 325
Post Tue Jan 19, 2016 10:44 am
Should just require a tap with a hammer on the spanner to release it if it's been done up properly, but many have been overtightened or even fixed with locktite or similar.
Try over tightening the fan belt first of all, and if that fails make up a short piece of 25mm flat steel bar with a 6.5mm hole drilled in one corner at the end. Remove one of the pulley fixing bolts, then bolt up the bar to it, using a slightly longer bolt. If you use the original, it will strip the threads in the pump flange.
Let the pulley turn, until the flat bar locks up against the spigot on the front of the pump flange.
Don't forget that it's a reverse thread!
Bally
Post Tue Jan 19, 2016 12:36 pm
Thanks reverse thread was the issue also the water pump is off I can see where the tension bar and springs go on pump does the other end just rest on the belt also is the pin with the shoulder go against the pump thanks
