jump pack on the wrong way now car won't start
cookster
Post Sat Jan 02, 2016 7:39 pm
Hi all basically BMW e30 325i painter at work has put jump pack on the wrong way round and tried to start the car.now battery light is on and car will crank but won't start.checked all fuses and the inter link one there all good none blew which ain't good.car stinks by alternator so would imagine it's cooked that but would of thought it would still start joy if anyone can shed any light thanks Ben
kam-325i
Post Sat Jan 02, 2016 7:57 pm
could of took the ECU out.............
cookster
Post Sat Jan 02, 2016 8:15 pm
May well of done I have a spare 320i one is it worth swapping that one over I mean lucky it's not a brand new other wise would of been proper curtains I hate painters and this makes me hate them more
Post Sat Jan 02, 2016 9:04 pm
The only thing I would expect to fail is the diode pack in the alternator. Disconnect the thick lead on the alternator and insulate it with tape, then fit a charged battery and check that there is 12 volts on the ignition coil + terminal when the ignition is switched on.
cookster
Post Sat Jan 02, 2016 9:28 pm
Well that could be good news the battery is absolutely knackered so probably worth another one of those will jump on it Mon and check the voltage. Can't here the pump at all while cranking either which is weird thanks for your info bud
cookster
Post Sun Jan 03, 2016 7:43 pm
Is there any fuses under the dash or anything or is it just the ones under the bonnet thanks
Post Sun Jan 03, 2016 8:43 pm
The only fuse that affects the engine running is #11 in the fusebox, for the fuel pump.
On 325i saloons only, there is another 'fuse', a fusible link, near the rear mounted battery, in the smaller lead.
The only fuse on an E30 that is not in the fusebox is on the left hand side of the heater box, and affects the heater temperature.
The check on the + terminal of the coil is to determine the state of the fusible link.
cookster
Post Sun Jan 03, 2016 10:16 pm
Brianmoooore wrote:The only fuse that affects the engine running is #11 in the fusebox, for the fuel pump.
No worries thanks for quick reply have checked all the fuses and cut open the fuseable link and that's good but I will do the check on the coil tomorrow and let ya no thanks
cookster
Post Mon Jan 04, 2016 10:04 am
cookster wrote:Well that could be good news the battery is absolutely knackered so probably worth another one of those will jump on it Mon and check the voltage. Can't here the pump at all while cranking either which is weird thanks for your info bud
Right bud fresh battery on cranks but no start and there is 12volts at the coil what next on the agenda to try can't here fuel pump at all so wondering if ecu is knackered have a 320 one is it worth swapping and trying It
Post Mon Jan 04, 2016 10:17 am
Try the 320 ECU, if it fits the plug. A 325 should fire up and run on it, albeit badly.
Just let the ECU hang on the loom - no need to unbolt the old one or bolt the new one into place.
cookster
Post Mon Jan 04, 2016 1:36 pm
Brianmoooore wrote:Try the 320 ECU, if it fits the plug. A 325 should fire up and run on it, albeit badly.
Done that still the same so wouldn't of thought it be ecu now
Post Mon Jan 04, 2016 2:42 pm
I didn't really think the ECU would be faulty, but it was an easy check to make, to eliminate it.
Time to start treating this like a normal non starting car, and find out exactly why it doesn't run - fuel, spark, timing or compression.
Switch the ignition on and pull out the DME relay (usually white, under the cover by the air filter). Does it click as you pull it out, and click again when you push it back in?
Check for sparks at a spark plug and fuel pump activity when cranking the engine.
Any immobilisers on this car? The electronics on these, especially if aftermarket, are likely to be far less resilient than BMW bits.
cookster
Post Tue Jan 05, 2016 9:05 pm
Brianmoooore wrote:I didn't really think the ECU would be faulty, but it was an easy check to make, to eliminate it.
Thanks for your help bud blew 2 relays the main white one for the dme and fuel pump changed them car now runs thanks for that
Post Tue Jan 05, 2016 9:55 pm
?? You can't 'blow' relays!
