Track Rods
Mitchen
Post Sun Dec 06, 2015 12:08 pm
When replacing these.. Is it just necessary to change the ends? or do you replace the inner part as well?
1990 320i Coupe SE
viewtopic.php?t=253048
scottybeemer
Post Sun Dec 06, 2015 12:20 pm
Mitchen wrote:When replacing these.. Is it just necessary to change the ends? or do you replace the inner part as well?
its not necessary if theres no wear,but i supose while your on with the job it makes good sense to do them
"you aint gonna take me alive, copper"
maxfield
Post Sun Dec 06, 2015 12:22 pm
Track rods are the bit from the rack to the track rod end.
I usually fit both of them. They're not particularly expensive. And quite often you will find that the track rod end has seized to the track rod, and it's more hassle unseizing that spending a few quid on a new one.
Mitchen
Post Sun Dec 06, 2015 12:35 pm
Thanks guys.. I just thought because the track rod doesn't seem to have rubber like the end, there would be nothing on it that could wear. But yeah they're all pretty cheap so will just get the lot. :)
1990 320i Coupe SE
Post Sun Dec 06, 2015 2:07 pm
??? No rubber in a track rod end joint either. Track rod has a ball joint on its inner end that can occasionally wear, and track rod end has a ball joint that frequently wears.
Post Sun Dec 06, 2015 5:46 pm
I think he means the rubber boot that usually gets an MOT failure Brian? I just replace the lot, chances are what you have is already 20 odd years old and seized up with rust, a pair of new is only £50
