e30 ignition barrel
mark_i
Post Sun Nov 08, 2015 9:22 am
how to disassemble the ignition barrel?
barrel comes out of the steering column with a pin in the slot in position 1 no problem.
Not obvious how barrel comes apart to the replace the worn tumblers.
TIA
mark_i
Post Sun Nov 08, 2015 11:01 am
thanks.
in the past I've been able to rebuild door/boot and glove box locks which can be taken apart.
Seems like the ignition barrel has no obvious way to release the centre cylinder from the body... :?
