So, I changed the valve cover gasket and bolts etc. Some of the bolts went in nicely at 10 nm, some won't grip at all and keep turning forever. I guess someone at some point has stripped some threads in the block?
What to do?
Valve gasket cover bolts...
BEERBOY123
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
maxfield
I would be taking them back out and inspecting the threads. I would be helicoiling them and using new bolts if it was my car.
HairyScreech
M20 or M5x?
M20s should have studs?
DHFiS
If the threads are stripped you will need an M6 helicoil insert.
BEERBOY123
Thanks. It's an M42. All the bolts are brand new from BMW (as were the gaskets)
An M6 helicoil insert, I'll have to research that.
maxfield
Standard thread size is M6 X 1.0
BEERBOY123
Easy to use? Do I have to tap them in or drill them or owt?
Can you get them upside down?
Should I do all the threads or just the buggered ones?
maxfield
They are easy to use, if you buy a helicoil kit, they come with everything you need. This is the kit I've got
http://www.ebay.co.uk/ulk/itm/111011855300
They are pretty self explanatory, but I'm sure there is a decent guide on YouTube.
I would inspect the threads, and only do the ones that need doing.
