Hello,
I have measure and cut my original propshaft m40 g240 to 1430mm size long to install to my e30 325i g260 but I see at the wikizone that the 325i propshaft originally size 1483mm and it is same with 324d.
I need to buy 325i propshaft but is it difficult to find, cann I use 324d as subtitude and does the size is same with 325i g260 box?
Thank you
Markus
propshaft identify 325i g260 and 324d
markus_74
All the diesels I've seen have had the large output flange on the prop which is different to the petrols
markus_74
Thank you for the info.
