i am located near Milton Keynes any one have one and the pin obviously i could borrow that would be great:D
many thanks
luke
m40 cambelt locking tool pretty please
swindler
I have them both in Kennington SE11 if that's any use
Tool not needed. All you need is a 10mm (?) drill bit to lock the flywheel at TDC, and a straight edge to lie across the flat on the top of the cam.
Cam won't move when you remove the belt.
