wheels??
Sambino
Post Wed Sep 16, 2015 7:58 pm
looking at purchasing some aftermarket wheels.
will 16" 9J
fit the e30??
Many thanks in advance
Sambino
Post Wed Sep 16, 2015 8:59 pm
ET?? ride height- car lowered by 40mm will be fitting 205/45/16
thanks
Post Wed Sep 16, 2015 11:46 pm
You'll need ET15 for a 9j rim
Sambino
Post Thu Sep 17, 2015 4:51 pm
It says off set is 9?? Will that be ok ?
Sambino
Is et off set?? I'm confused- but also don't know much about wheels a˜a
Post Thu Sep 17, 2015 5:06 pm
Yep, ET is offset.
9 will be ok, but you'll need the arches rolling
Grzesiek325i
Post Fri Sep 18, 2015 9:55 pm
Et15 will touch 51mm leg. Around 17 up
16x9j et15. 16 inch diameter, 9 ich width and offset 15mm
