Hi I have 2 questions.
Is it 17mm hex required to get the fill and drain plugs off a getrag gearbox?
Do they have ay kind of washer or gasket on them?
Thanks in Advance
Gearbox Fill and Drain Plugs
17mm yes, and no washer they don't have any kind of shoulder - like a big grub screw they just nip up into the casing.
I read of someone using a 17mm headed bolt with the double nut method if you don't have the size of hex key.
Thanks for that, and thanks for the tip - I was just about to order a 17mm hex!Jookeone wrote:17mm yes, and no washer they don't have any kind of shoulder - like a big grub screw they just nip up into the casing.
Done that many times in a pinch. can work a treat, especially if you can dab a spot of mig on there to hold it as well.Jookeone wrote:17mm yes, and no washer they don't have any kind of shoulder - like a big grub screw they just nip up into the casing.
Used a hex socket on mine with a ratchet - came out pretty easy. Make sure to get the correct oil as well > http://www.e30zone.net/e30zonewiki/inde ... il#Gearbox
