I'm making a tool to slide the front wheel bearing on straight. This is for a 89 320i Touring.
Does anyone have an axle, and or bearing laying around? I need dimensions for:
1. Bearing Inner Diameter
2. Bearing Inner race thickness
3. Length of the thread on the Axle end
If anyone has the actual FAG part number for the bearing so that I can reference their drawing, it'd be even better.
Thanks in advance.
320i Wheel bearing Sizes
jmc330i
Is a tool really needed?
A new bearing should slide on easy enough, maybe with some gentle persuasion from the 36mm socket (I think it's 36mm that presses on the inner race) and a wooden mallet to get it pressed on far enough to use the hub nut to wind it home.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- **BANNED**
That's the way I have always done 'em!jmc330i wrote:Is a tool really needed?
Youth is wasted on the young.
tejawxyz
Didnt want to risk it being misaligned and damaging the inner race, thats all.
jmc330i
It wont. Its really easy to do.
James
'91 325i Sport
'91 325i Sport
tejawxyz
I've done a lot of searching for the FAG and Meyle part numbers with no luck with dimensions for just the bearing. Thats why I was asking if anyone has one, if they can measure one to the closest mm.
gromgsxr
i managed to slide the old hubs off the stub axle and the new ones on without any tools when i did mine.
HairyScreech
axle is 31mm, outer race is unknown as it is part of the hub, end nut is an M24 (i think 1.5mm thread, its in the 5 stud info I posted a while back), bearing width is also in there I think.
Totally no need for a tool, they should slide on with a good shove unless the axle is a bit grotty.
