Rev Counter
cobbler2u
All clocks work bar the rev counter.
Hep needed
Hep needed
milescook
Try taking the cluster out, there is a guide on the wiki. You can unbolt it pull down and slide left out. Check the screws are tight and the connectors. Also check the white plug bottom right is in ok. If that's no help I have a spare cheapish, the components are easy to change.i believe it shouldn't matter as the white plug determines how many revs it should show based on the engine but get a second opinion here.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
Rev. counter dies when the SI board batteries do, if they are of the NiCd type.
Do the SI LEDs work properly?
cobbler2u
What is the SI board batteries.Brianmoooore wrote:Rev. counter dies when the SI board batteries do, if they are of the NiCd type.
sorry if stupid queston.
Thanks for reply
The memory back up batteries on the circuit board in the front half of the instrument cluster, that contains all the electronic circuitry for the cluster, except for the speedometer/odometer and the brake pad warning light.
SI indicator is the row of green LEDs at the bottom of the cluster, with a yellow one and a red one at the RH end, and three lights above for 'oil service', 'inspection' and a clock synbol.
- E30 Zone Meets/Events Team
I have the same issue, and I have 3 leds on atm, but no rev counter, 1984 chromie M10
cobbler2u
just ordered 2 new batteries.
They are welded on will post outcome when all done
Have you tested the originals?cobbler2u wrote:just ordered 2 new batteries.
cobbler2u
no just bought newwillnz wrote:Brianmoooore wrote:Have you tested the originals?cobbler2u wrote:just ordered 2 new batteries.
Wealthy e30 owners would not be seen dead doing testing...
Do you even know which version of the SI board you have? The two types of battery are not interchangeable.
cobbler2u
now you tell me lol
what the differnce
what the differnce
1.8 volts each.cobbler2u wrote:what the differnce
Take out your cluster, remove the SI board, and identify which type of board you have. While you're at it, test the batteries.
cobbler2u
batteries changed still not working
