Last sunday,after two weeks of inactivity i wanted to take my E30 for a ride but...surprise,it won't start. I checked spark plugs,cables and the rotor. Everything ok. Then i noticed a thing,once you turn the key you don't listen the fuel pump. So i thought "fuel pump is gone". At this point i ordered one,it arrived friday i installed it but nothing. My E30 still don't want to start. After some internet research i discovered that there's a relay that "drives" the fuel pump. I checked it but it seems ok and you can clearly listen its "click" when you turn the key.
In my opinion the problem is that the 12v don't reach the fuel pump but i don't understand why. I checked it with the key turned and at the + and - of the fuel pump the multimeter signed 0 volts
Have you got any idea?
Thank you in advance!
EDIT : it's an '84 320i with L-Jetronic injection and external fuel pump.
