I'm in the process of putting an e46 rack on.
I am using the e30 inner and outer track rods.
The wiki says to re-install the locking washer / locking plate between the inner track rod and the rack.
However the e46 rack lacks the indent to locate the locking washer, so it would not actually lock.
Is this right?
So do I install without the locking washer, or do I need to put it on just for the extra 2mm or so it gives?
e30 track rods onto e46 rack
I don't fit the washers, as you say there is nothing for them to lock into.
maxfield
As said by Dan. I've never bothered with the washers. Just tighten then up and not worry. I've seen people mention thread lock, but there's not turnin force on them for them to come loose.
jslot
Excellent thank you both.
TriggerFish
You might need to drill a hole too for the pressure in the boots to equalise, other wise they may pop off on full lock
ajay
Thats only if your happy bodging it!
I took the track rods out of an E46 rack the other day, they had been thread locked in and were a nightmare, I thought the rack was going to break at one point because I had so mush leverage on it!
jslot
What do you suggest?ajay wrote:Thats only if your happy bodging it!
TriggerFish
Using e46 inner rods is the better bet, I think.
ajay
Triggerfish, pls don't take this the wrong way but have you actually tried to use E46 inner rods yourself..?
jslot
What do you suggest?ajay wrote:Triggerfish, pls don't take this the wrong way but have you actually tried to use E46 inner rods yourself..?
TriggerFish
No offense takenajay wrote:Triggerfish, pls don't take this the wrong way but have you actually tried to use E46 inner rods yourself..?
Do they not work after all then?
