CID PLUG
Post Mon Aug 10, 2015 10:31 am
Hi all, almost done to my coverting to M1.3 on my M 1.0. just wondering the CID from the HT lead, where did i need to connect?
i got 2 spare plug according from the loom map is say CPS or CID.(on number 15 & 16). is the CID from the HT lead plug in this 2 plug? and which number i need to plug in? 15 or 16?
Post Mon Aug 10, 2015 9:36 pm
CID and CPS sockets are identical, and are normally fitted to the same metal bracket at the top, front of the engine that holds the big diagnostic socket.
The easiest way to check which is which is to plug the CPS into both in turn, and see which makes the fuel pump run and the ignition system produce sparks when the engine is cranked. When you've identified which is the socket for the CPS, then the other is for the CID.
CID sensor should be on #6 spark plug ead.l
