Hi guys, i'm fitting fog lights to my car and i have found the two cable to connect the lights in the front bumper, i also have the two fuses that go in slots 29/30 i believe? also the fog light switch, i just can seem to find a relay?
apparently its a K8 relay which is identical to K4 but where would i buy such an item??
Any help would be great thanks!
FOG LIGHT HELP
sweep
The car wont have this fitted if it will need fitting in.
From anyone breaking an E30.Jamiestrutt wrote: apparently its a K8 relay which is identical to K4 but where would i buy such an item??
You also need to fit a bulb and holder to the tell tale position in the instrument cluster.
Jamiestrutt
What do you mean sweep? I'm unsure what you mean by it will need fitting in?
Thanks Brian do I have to remove the speedo to add the bulb?
