E46 rack - Track Rods
jslot
Post Mon Aug 03, 2015 8:22 am
I've read a thread about E46 rack rubber boots bellowing because the E46 rack boots vent through the hollow E46 inner track rods. So is this actually a problem? (It's not mentioned on the wiki). And what is the best choice of track rods for an E46 rack, is it E46 inner and E36 outer?
sweep
Post Mon Aug 03, 2015 8:26 am
Both my cars have e46 racks,i used e30 tie arms and tre's..the boots do suck in so i put 2 8 th holes in the end rubber disc's at the ends on 6 and 12 oclock positions to allow the air to get out. using e46 boots
Lurch320i
Post Mon Aug 03, 2015 11:25 am
Does this method not let dirt and grit inside the rack?
I have the same problem on full lock where the boots compress and suck in
sweep
Post Mon Aug 03, 2015 11:30 am
The holes are only small and are clsosed up so to speak when not presured up
Lurch320i
Post Mon Aug 03, 2015 7:05 pm
Cool thanks a‘aaa»
jslot
Post Mon Aug 03, 2015 7:59 pm
Yep thanks Sweep☺
potatomash
Post Wed Aug 05, 2015 12:54 am
I used e46 inner with e36 outers no problems
