Burning smell, HELP
ETERNITY
Post Sat Aug 01, 2015 9:44 pm
A few weeks ago I could smell a heavy burning smell obviously coming from wires.
I changed my battery because it was going flat every morning, the car had been running fine for about 2 months and last week I smelt the same smell but not as intense and the next morning flat battery again. So I tested a new battery and it worked fine for 2 days and now it's gone totally flat again.
I suspect that the heavy smell previously has burnt some wires and now there's a open circuit.
Any advice please
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
Post Sat Aug 01, 2015 9:50 pm
Use a meter to find out where the drain is going!
ETERNITY
Post Sat Aug 01, 2015 10:40 pm
Ok will identify where the drain is going and report back
ETERNITY
Post Mon Aug 03, 2015 9:02 am
Ok checked with a meter and the battery seems to be low in voltage and fluctuates down.
My next step is purchase a better battery because this is a economy one. However there seems to be a surge because
the battery is new and it was fine for a few days and now won't even respond to jump leads. Totally dead.
And this has happened twice
Any further advice Brain.
sweep
Post Mon Aug 03, 2015 9:33 am
Is the belt ok? tension?
Post Mon Aug 03, 2015 9:45 am
You're supposed to be measuring current (amps), not voltage.
Sweep makes a valid point.
ETERNITY
Post Mon Aug 03, 2015 1:04 pm
Ok will check Belt/tension and also measure amp
Will report back
