Guibo replacement guide
Sonatine
Is there a guide available for this process? Didn't see one on the wiki.
It involves accessing and unbolting the prop. centre bearing mount. This allows the prop to effectively be shortened enough to change the guibo by dropping the centre, so that the prop. is 'V' shaped.
Don't forget that the arrows on the outer edge of the guibo, by each bolt hole, MUST point towards the flange they are bolted to.
