ignition switch
MURRAY1
hi folks , anybody had this one .ignition switch starts and stops the 325i fine , but when turned off all the warning lamps stay on and will flatten the battery obviously if left on , have to disconnect the battery ...help ...
Joe-s
Could be a faulty ignition switch or a shorting wire some where try unplug ignition switch see if the lights go off just a thought hope this helps
