Hi, I'm looking to get the tallest diff poss for my e30
So i saw this e46 2.35 diff and wondered if anyone knew if it was possible to re-build an e30 diff with the e46 diff internals
http://www.ebay.co.uk/itm/BMW-E46-3-SER ... 3a8f729dca
thanks
Using parts from an e46 diff - is it possible ?
maggspower
- Turbo Farmer Tractor Driver
I don't think the internals are interchangable on these Jim.
Why do you want such a tall ratio?
Contact: theengineshedonline@gmail.com
HairyScreech
Well it "looks" to me like it's biased on an 188mm casing.
Might be possible but until someone tries who knows?
The gasket kit is the same as quite a bit of stuff, but I think that might be because to 188 and 210 gasket is the same.
http://bmwfans.info/parts-catalog/33101214618/
That said, it only looks like its throwing up new style small engine stuff, not a single M with a 210 diff on that list.
The output is also 84mm which is a 188mm case thing.
No internal diff bits available from BMW though, couldn't check if the bearings are shared with anything that is know to work.
Thread on fitting an E30 diff to an E46, looking the same size case there:
http://forum.e46fanatics.com/showthread.php?p=11870187
Following this they seem to say the M5x engined e46 is 188 case.
http://www.bimmerforums.com/forum/showt ... 88mm-diffs
The pinion shaft is too short I believe, looked at it years ago
jimbom30cab
- Tech 1 freak
Thanks guys, interesting stuff, I just wanted to put a really tall diff on the M52 to see what it was like, for shits and giggles really.
Thought about doing a long run in 6th with a super tall diff to see what the best MPG is i can get
