HOW 2 GET A 155KW ON THE A 325I FLYWHEEL
G-string
2.7 ETA,272 deg ALPINA CAM, PORT & GASFLOW,38mm EXHAUST BRAUNCH SYSTEM WITH A 323I LSD(3.63:1) AND A REMAP 2 SUIT
E30Adam
What exactly is the point of your post??
Are you telling us what you've done, are you passing on some info you've found out?
You don't exactly go into much detail and it's not something that hasn't been done before, you'd probably be better off putting a bhp figure rather than a KW figure as most people don't understand KW's
Turbo-Brown
- Boost Junkie
What's that, about 206bhp?
Not bad. Reckon you could do a hell of a lot better with a decent engine management system though.
Boots_Walker
what does the differential have to do with 155kw at the flywheel?
