Fan blade bent and catching radiator
FEP
Post Sun Jun 14, 2015 10:21 pm
I fitted a new genuine fan about 4 years ago on my M20 325i.
Opened the bonnet today to investigate a rattle on start up and found that one fan blade had broken off and the one next to it was twisted and bent forward at the tip and beginning to cut a groove in the radiator fins. 8O
Any ideas as to what has gone on here?
The water pump is fairly new and the bearing on it is good without any play. The rad is also reasonably new - aftermarket item and it is firmly secured and doesn't move around.
The other fan blades have at least 5mm clearance from the rad.
Thoughts?
FEP
Post Sun Jun 14, 2015 11:40 pm
Hows your engine mounts ?
FEP
Post Mon Jun 15, 2015 11:12 am
I reckon they're OK but good thought. I'll give the engine a good push to see what the fore and aft movement is like.
aimlessrock
Post Tue Jun 16, 2015 1:32 pm
check the fan is bolted onto the viscous coupling the correct way round.
E30 320i Convertible (1989)
190 Mercedes (1988)
FEP
Post Tue Jun 16, 2015 4:47 pm
aimlessrock wrote:check the fan is bolted onto the viscous coupling the correct way round.
It is!
I'd have much bigger problems if it was on the wrong way. :mad:
xavier
Post Wed Jun 17, 2015 3:27 am
I had the same issue a few months back. I checked all the mounts for the engine and gear box. they were all good. I changed the fan and the issue was resolved. I never found the cause. My fan was very old though. I think it may just have been the plastic going brittle due to heat and age. A did spend a bit of time when I put it all back together making sure the radiator had plenty of distance between the itself and the new fan.
FEP
Post Wed Jun 17, 2015 9:12 am
xavier wrote:I had the same issue a few months back. I checked all the mounts for the engine and gear box. they were all good. I changed the fan and the issue was resolved. I never found the cause. My fan was very old though. I think it may just have been the plastic going brittle due to heat and age. A did spend a bit of time when I put it all back together making sure the radiator had plenty of distance between the itself and the new fan.
Thanks for that xavier. How did you adjust the distance between fan and rad? Doesn't seem to be any scope for adjustment.
**BANNED**
Post Wed Jun 17, 2015 8:21 pm
I would 'think' that the fan ageing is the root cause of your problem.
Assuming that the engine is not throwing it's self around,of course!
I fitted a pair of engine mounts from Burton,the Ford tuning place,a while back...I have no engine movement issues.
Youth is wasted on the young.
FEP
Post Wed Jun 17, 2015 9:24 pm
daimlerman wrote:I would 'think' that the fan ageing is the root cause of your problem.
Ageing? It's only 4 years old Malc.
xavier
Post Thu Jun 18, 2015 12:02 am
My car had a knackered Air con system, with the air con radiator in front of the engine radiator. When I replaced the fan I took both the radiators out. I threw the Air con one in the bin. I think with this out I managed to get the drivers (RHS) top mounting point back a bit. I will take a look at the weekend. Cant remember exactly what I did with the mounting point.
**BANNED**
Post Thu Jun 18, 2015 4:02 pm
4 years old or 24 years old,your fan is buggered,it's lost one blade and bent another!
So why?
Fan can only belt the radiator if the engine moves forward or the radiator moves back,or if the waterpump bearing is buggered,or if the fan is not fixed properly.
Which is your problem?
FEP
Post Thu Jun 18, 2015 4:08 pm
So why?
Well I must admit, I'm beginning to think that one blade broke off just because these things can happen, and in doing so, it bent the next blade enough for it to catch the rad.
