Lollipop Eccentric Bush Orientation??
JoshH
Post Mon Jun 08, 2015 12:09 pm
Hey,
I have a set of M3 eccentric lollipop bushes. But I can't seem to figure out which way to fit them.
I'd always figured the hole should be towards the wheel. The powerflex instructions seem to say the same - but their diagram shows the opposite??
On googling for images etc it seems people have fitted them with the hole either nearest to the car or nearest to the wheel!
Please could someone clear it up for me as I plan to fit them today.
scallyally
Post Mon Jun 08, 2015 12:26 pm
Search for "bushes" on the wiki and all will be revealed :D
jmc330i
Post Mon Jun 08, 2015 12:30 pm
There should be an arrow on the bush and a raised dot on the lollipop - fit the bush with the arrow and dot aligned. The raised dot can often be covered by rust/dirt so it's not easy to see. The hole in the bush should be closest to the chassis rail when fitted as this moves the wishbone towards the outside of the car and so the wheel/hub position forward in the arch increasing the caster angle.
James
'91 325i Sport
'93 318i touring 16v
jmc330i
Post Mon Jun 08, 2015 12:33 pm
scallyally wrote:Search for "bushes" on the wiki and all will be revealed :D
Got a direct link? The only references I found were to the eccentric bush part number and a link to fitting concentric bushes.
James
'91 325i Sport
scallyally
Post Mon Jun 08, 2015 12:42 pm
Click on the M3 eccentric bush (hi lighted in blue) and photo fitting instructions are there, (at bottom of page)
jmc330i
Post Mon Jun 08, 2015 12:44 pm
Bottom of what page? :mad:
Can you copy and paste the link :D
James
'91 325i Sport
blazed
Post Mon Jun 08, 2015 12:51 pm
jmc330i
Post Mon Jun 08, 2015 1:49 pm
Ah, didn't clock that was an M3 bush :o: it just looks like a dodgy pic of the concentric bush from the pics above it.
Thanks :thumb:
James
'91 325i Sport
JoshH
Post Mon Jun 08, 2015 8:15 pm
That last pic looked like a poor pic of a normal bush to me too!!
Anyway all done now :) thank you for the help lads
