Not getting hot air m50 swap
Davidchurch
Post Mon Jun 01, 2015 8:00 pm
As the title I'm not getting any hot air through the cabin. I've read that the heater control valves have problems and you can bench test them to see if they are working properly. Question is can you take the valve out leaving the pipes in so I don't have to remove to 2 hoses as they are a bit of a pig to get to?
Any help would be great. Thanks.
Post Mon Jun 01, 2015 8:01 pm
Have you got the hoses the correct way around?
Davidchurch
Post Mon Jun 01, 2015 8:11 pm
Yeah, it was working only just stopped the other day.
Post Mon Jun 01, 2015 10:58 pm
The common problem with the heater valve is that it blows its top and dumps your coolant over the passenger side carpet. I have never known a correctly connected (flow direction) valve stop the heater producing warm air.
Does the heater unit produce large quantities of cold air?
Davidchurch
Post Tue Jun 02, 2015 7:45 am
Yes when i put it on hot its cold but then when i put it on cold its so much colder and chucks it out.
