vibration through steering wheel on braking
Bally
Hi Have a 325 auto cab and am getting a slight vibration through steering wheel on braking , could it be wheel balance or do i need to look at bushes any help appreciated
Bakea012
I would start off getting your disks checked for warping most garages will be able to check for you.
maxfield
Your discs could be warped, more so being an auto as you're harder on the brakes. This is usually checked with a DTI gauge, but by the time you've bought a DTI gauge you're half way to buying discs and pads.
There is also a chance it could be the bushes on the rear of the front wishbones, it is worth checking.
