Cabbie 'horseshoe' gas struts
Strugs
Post Wed May 06, 2015 10:23 am
Mine are goosed (standard!)..
Anyone heard of or used these?
http://www.ebay.co.uk/itm/151529988602? ... EBIDX%3AIT
minesapint
Post Wed May 06, 2015 10:36 am
Strugs
Post Wed May 06, 2015 1:45 pm
Top stuff! Think I'll give these a go then.. :)
Nice one, cheers.. :cheers:
viz007
Post Wed May 06, 2015 4:58 pm
I bought these ones and am very happy with them. They are apparently OEM but without the BMW branding.
http://m.ebay.com/itm/160772454905?txnId=1229075190006
petchy
Post Fri May 08, 2015 11:49 pm
Just fitted this 'able-goods' set from ebay, posted from Germany, very happy!
One on the left is the old one, on the right is the new one
ianev
Post Sat May 09, 2015 10:52 pm
cool. any tips or simple job?
petchy
Post Sat May 09, 2015 11:00 pm
Simple, little circlip holding top and bottom, couldn't be easier! :D
ianev
Post Sat May 09, 2015 11:14 pm
Strugs
Post Sun May 10, 2015 8:29 pm
petchy wrote:Just fitted this 'able-goods' set from ebay, posted from Germany, very happy!
Cool, that's the ones I've gone for.. :clap:
ianev
Post Mon May 18, 2015 8:09 pm
okay the able goods have arrived, any further tips before I crack on?
petchy
Post Mon May 18, 2015 8:11 pm
Don't get wholloped in the heed by the horseshoe!! :D
ianev
Post Mon May 18, 2015 8:55 pm
:mad: hahaha! do just get these circlips off off with a screwdriver? any other tools required? does the strut need to be extended?
any info accepted with grovelling thanks
petchy
Post Mon May 18, 2015 9:04 pm
It really is very simple, just jammed the circlips off with a screwdriver then pushed them back on when the strut is fitted. The struts will be extended as the horseshoe will be open!!
ianev
Post Mon May 18, 2015 9:29 pm
cheers pal - get it back from the garage tomorrow (service), will try when I get home.
need to replace rubber aerial grommet also - hope I've got the right part... thank again.
Strugs
Post Wed May 20, 2015 12:40 pm
'Able goods' versions on mine now and work perfectly. Easy fit, too. :)
ianev
Post Wed May 20, 2015 9:51 pm
the c clips were ridiculously hard to get off. I would suggest removing the top c clips first (as more accessible), then freeing off the top of the strut, wiggling it a bit top give more access to the lower.
please tell me how you replaced the c clips as mine look a bit mangled and I doubt I'd have the patience to get them on even if they'd go on anyway.
anyway job done and tonneau stays up 8)
ianev
Post Wed May 20, 2015 10:35 pm
oh yes - an upturned plastic washing basket makes the perfect prop
