Coolant sensor plug
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri May 01, 2015 3:33 pm
The wire going into the coolant level sensor broke off today, just where it joins the rubber plug. Are there any other BMWs with a similar plug that I can scavenge, or do I have to find another E30 and hope the wires aren't as perished?
Grrrmachine
Post Fri May 01, 2015 10:10 pm
Yeah, it's the later one with the straight pins. I know the plugs themselves are the same diameter as all the other plugs (headlights, indicators etc), but all those are 90-degree elbows and these ones are straight.
bimanut
Post Fri May 01, 2015 11:42 pm
I uncliped the 90° plastic housing from the connectors heatshrinked the ends for insulation when I made my fan loom
