Car in question is a 316i touring with manual gearbox.
Haynes says to check level whilst car is on level ground, my problem is that without having the front end up on ramps
there is no way I can even reach the filler plug to undo it, let
alone getting the new oil container anywhere near enough
to top it up.
Suggestions, please.
Topping up transmission oil.
- Brianmoooore
Put it on four ramps.
- **BANNED**
IIRC,the filler/level plug is about halfway down the side of the 'box,so unless the turd is stood on it's bumper,you will be able to get enough oil in to keep it happy.
I use an oil syringe for the job.
And I use ATF,BTW.
And I use ATF,BTW.
Youth is wasted on the young.
- Brianmoooore
A mate of mine used to work for Land Rover R&D. He was once sent to investigate the high number of diff. failures reported at a military establishment who bought a LOT of their products.daimlerman wrote:IIRC,the filler/level plug is about halfway down the side of the 'box,so unless the turd is stood on it's bumper,you will be able to get enough oil in to keep it happy.
Cause of the problem was diff. oil being changed on a single pair of ramps.
- Brianmoooore
Gearbox, not diff.BenHar wrote:Diff level plugs tend to be on the back, not the side.
Ben
Brian, you brought up the diff, not me.Brianmoooore wrote:Gearbox, not diff.BenHar wrote:Diff level plugs tend to be on the back, not the side.
Ben
- BHadley
- Contact:
Can also be topped up "beer bong" style with a hose running down the gear stick area once the padding is removed, pop funnel in end fill with oil and raise arm to get flowing... Look under car every so often and remove when flowing out of filling port.daimlerman wrote:IIRC,the filler/level plug is about halfway down the side of the 'box,so unless the turd is stood on it's bumper,you will be able to get enough oil in to keep it happy.
And I use ATF,BTW.
- Brianmoooore
I did, but that's because I don't have an example of gearboxes failing through being incorrectly filled, whereas I do have anecdotal evidence of diff. failures.BenHar wrote:
And I was pointing out that diffs are usually filled from the rear which means that they will be more affected by the angle than a gearbox filled half way along it's side.Brianmoooore wrote:I did, but that's because I don't have an example of gearboxes failing through being incorrectly filled, whereas I do have anecdotal evidence of diff. failures.BenHar wrote:
I put it on ramps and jack the rear up onto axle stands when I do it.
Ben
