Rear wheel bearing issues
Gok
Post Wed Apr 22, 2015 6:51 pm
I had my trailing arms shot blasted and powdercoated.
However the new rear bearings don't need pressing in they just slip in with a gap remaining.
2 questions I have.
1) does the trailing arm bearing housing have a sleeve, which I am missing?
2) Are there different size bearings? - I have 75mm outer diameter for the bearings.
A picture speaks a thousand words. So here are 2!
I need to confirm the internal diameter. I don't understand why this doesn't fit.
Any help would be much appreciated.
Post Wed Apr 22, 2015 11:55 pm
Who supplied the bearing?
Gok
Post Thu Apr 23, 2015 6:42 am
Hi Rav,
I got it from ECP a bit back. I was trying to find the original bearing to confirm fitment. I am confused. :?
TPS
Post Thu Apr 23, 2015 6:55 am
Have they supplied for an Abs/non-Abs car by mistake?
Gok
Post Thu Apr 23, 2015 7:04 am
Hello TPS,
So the sizes differ between these then? The arms are from an ABS car a rolling shell I bought. I will have to check on the bearings.
motormanmick
Post Thu Apr 23, 2015 7:45 am
you have been supplied with the incorrect bearing, sizes given below, cheers.
Non ABS bearing size 39X72X37
ABS bearing size 42X75X37
Gok
Post Thu Apr 23, 2015 7:49 am
Thank you motor Motormanmick,
I wI'll speak with ECP about this error. Much appreciated as I thought it wasn't right.
Many thanks
Post Thu Apr 23, 2015 7:57 am
Sorry dude, fell asleep. LOL :mad:
