Fan speed controller fell off
E30REDD
Post Wed Apr 22, 2015 2:51 pm
Someone stupid was pulling on the controller or whatever it's called and it fell off along with some other parts. The parts in my hand are all the parts I could find and I hope it's the only parts needed.
Is the threaded gold metal thing just gonna be threaded over the gray metal rod that is sticking out from the panel, and then the plastic controller is going to be pushed on to the metal rod?
That's how I thought it should be assembled and I assume I have to remove the whole panel or at least the stereo in order to hold the metal rod as it just wants to fall further into the panel if I put pressure on it.
So, before I tear anything apart, am I thinking correctly and am I not missing any parts?
Post Wed Apr 22, 2015 6:51 pm
I think something's gone wrong with your pic.
jmc330i
Post Wed Apr 22, 2015 6:54 pm
Pic is working fine for me Brian.
James
'91 325i Sport
'93 318i touring 16v
Post Wed Apr 22, 2015 6:55 pm
All I can see is a minus sign in a circle!
jmc330i
Post Wed Apr 22, 2015 6:57 pm
Hmm. Hang on, I'll screen shot it...
James
'91 325i Sport
jmc330i
Post Wed Apr 22, 2015 6:59 pm
James
'91 325i Sport
E30REDD
Post Fri Apr 24, 2015 1:31 pm
Brianmoooore wrote:All I can see is a minus sign in a circle!
Are you able to see the picture jmc330i posted?
Otherwise this link should work: http://img.photobucket.com/albums/v456/ ... zv8q7d.png
Post Fri Apr 24, 2015 2:17 pm
Yes, can see that one.
All parts are present, but if the brass part was removed without unscrewing it, then the plastic internal threads on the switch must have stripped.
The brass part is just an externally threaded nut/bush to hold the switch in position. The knob appears complete, and just pushes on.
If you need access behind, I'd suggest removing the rear centre console, followed by the front centre console.
E30REDD
Post Fri Apr 24, 2015 2:19 pm
Brianmoooore wrote:Yes, can see that one.
Okay, thank you. :)
