Leak!!
tips
Post Sun Apr 19, 2015 9:50 am
Hi e30 newbie here
I left my car sitting for a few days because i had a popped coolant hose..anyway i moved her today and shes leaking from the farside skirt its a preface lift so no kit..no wet carpets its just leaking driving me mad!! Any ideas?
Post Sun Apr 19, 2015 11:41 am
Does it have a sunroof? If so, open it and use a length of stiff wire (bicycle brake cable or curtain wire, for example) to 'dyno-rod' the drain holes while you flush water down them to clean out any crud.
Post Sun Apr 19, 2015 7:53 pm
Speedtouch wrote:Does it have a sunroof? If so, open it and use a length of stiff wire (bicycle brake cable or curtain wire, for example) to 'dyno-rod' the drain holes while you flush water down them to clean out any crud.
I'd check the sill drain slots before doing that!
Post Sun Apr 19, 2015 9:26 pm
Yes, best to check those too, and the door drain holes while you're at it! :wink:
