m30b35 bogging
ligeh
Post Mon Apr 13, 2015 11:57 pm
Just when you go to rev it from idle, sometimes it bogs right down trying to stall, soon as you remove foot from pedal it revs up a little.
Any ideas where to start looking? Thinking its over fuelling but mpg is about 18-20 driving fairly heavy which seems about right?
Post Tue Apr 14, 2015 12:11 am
Check the blue sensor.
Also have a read from the link below.
http://www.bimmerfest.com/forums/archiv ... 91632.html
Post Tue Apr 14, 2015 9:28 pm
Sounds more like under fuelling to me. Check that the throttle position switch is working reliably when the throttle is moved off of its stop and released again, and that the switch operates immediately the throttle leaves its stop.
Also, consider getting the injectors rebuilt. (See "injectortune" in our traders' forum).
