High/Low Impedence Injector Spec
Eddie1990
Post Thu Apr 02, 2015 1:27 pm
How can you visually tell the difference between the high and low impedance injectors?
Also what are the resistance values they should be showing?
Thanks,
gromgsxr
Post Thu Apr 02, 2015 1:54 pm
10-16 ohm high 5ohm or less low usually, get a ohm meter between the 2 pins
