Hi Zoners,
Does anyone know if there is a visual difference between the high compression 325i engine to a standard 325i engine??
thanks,
tripper
HIGH COMPRESSION 325i ENGINE
gromgsxr
on the left hand side where the engine number is there will be a code 256K or 256E, k is lower comp and e is higher comp. as far as im aware there were 3 diff comp ratios, 8.8-1 9.4-1 and 9.75-1 the 9.75 uses a different crank pulley it has no teeth on it as the engine rpm signal comes from the flywheel
Tripper
Thanks gromgsxra˜„
Apologies, but where exactly on the left hand side?
Tripper
Tripper
Grrrmachine
- E30 Zone Wiki / Team Member
The plate is just above the joint with the sump, near the dipstick. It's only the size of a matchbox, and is easier to see from underneath the car.
"Plate" might be a bit misleading, suggesting something that is screwed or riveted on. It's just a shallow boss on the block that has been machined flat and engraved.Grrrmachine wrote:The plate
