E30 running poor missing?? Help needed
aarc
Mon Mar 30, 2015 10:10 am
Hi all ive just taken my e30 out after being parked in the garage for over a year usually it would start up no problem and run fine it has been parked up over a year, so I started it up yesterday and it did take some time to start, when it did start it was missing and throwing out white cloudy smoke, I did check the water and oil before the start up and they were up to par.
it took a few attempts to start but eventually I got it to idle but it was running way too poor and eventually something gave way and now it doesn't start, any ideas as in where I could start to look and what I can do, ive cleaned the plugs as they were black, bearing in mind the car drove without fault and ran sweet prior to storage?
advice much appreciated
maggspower
Turbo Farmer Tractor Driver
Mon Mar 30, 2015 10:18 am
Fresh fuel would be a start.
It will idle a bit lumpy for a bit anyway as the ECU sorts itself out.
aarc
Mon Mar 30, 2015 12:42 pm
I put a full jerry can of fuel in her and still running poor any other suggestions
Mon Mar 30, 2015 1:48 pm
If we has some idea as to which particular E30 model it is, it would help!
aarc
Mon Mar 30, 2015 3:51 pm
Ah sorry yh buddy its a 1989 bmw e30 325i m20b25
Mon Mar 30, 2015 6:22 pm
Did it get progressively worse as it warmed up?
Will it start now that it's cold?
